unable to update to iOS5
Graham Muz
Dec 2, 2011
Ever since the latest software version became available I have been unable to complete the download via iTunes (I am using the latest 10.5 version of iTunes) as the down load fails each and every time at the processing file stage and I get the following error message:
iPhone Software Update (processing file)
There was a problem downloading the software for the iPhone “Grah_Mus’s iPhone”. The network connection timed out.
Make sure your network settings are correct and your network connection is active, or try again later.
I get this regardless of if I am using the network in the office or at home.
has anyone else had this issue or make suggestions on how to overcome. Is it likely to be an issue with my laptop perhaps a cache issue or the like? Am I likely to now have a number of versions of the downloaded file stored somewhere on the laptop that I should try and find and delete, and if so where are they likely to be?
Any advice welcome, thanks in advance.
showguy
Dec 2, 2007
769
Long Island, NY
I would uninstall iTunes, reboot your computer and reinstall the current version. If it happens again I would try to temporarily disable your antivirus software while you are downloading and installing iTunes.
verwon
Jul 29, 2011
1,015
121
Seattle
  • Like
Reactions: Bennyboy
