Understanding Tapping on Webpages
invincible569
Jun 30, 2007
79
As some of you know, tapping once on the top of the screen takes you back to the very top which is helpful. Well I've been trying to figure out why some tapping is magnified more than others. From what I have been experiencing, its about where you tap. The Cell you are tapping into, lets say on this forum.. the smaller the cell, the larger it will magnify. For example, tap on the replies column and you will see that it magnifies to the max. Now tap on the left side where there is a thread and it will fill up to that cell size.
JnC
Jun 17, 2007
333
I found that "pinching" things like the way you really would pinch with a thumb and forefinger, works a lot better than trying to use two fingers (the thumb seems essential for making smooth zooms).
