Unidentified network error
Rex Roque
Jan 7, 2012
Hi everyone. Ive been having problems getting a connection from my laptop using my iPhone 4s' personal hotspot. If i connect it through usb i get the error "unidentified network". But when i connect to my iPhone's PHS via wifi, it connects. Ive tried a different iPhone with similar network settings and im able to connect via usb. Any ideas why?
Thanks in advance :)
laughjimbo
Aug 2, 2010
62
Hertfordshire, UK
No it can be connected via USB as I do it all the time, that way it also charges your phone. Sorry but I don't know why you are getting this error. Unless it just did not install the phone properly. Does it work ok when connect to iTunes via USB with the wifi sync box unticked?
Sent from my iPhone 4S using iCafe app
iphonewarrior
13,847
699
Try resetting your network settings. Be aware you will lose all of your previously saved wireless networks.
Try alternative USB cables as well.
Rex Roque
Jan 7, 2012
Its weird because after several tries it started working :) everything looks goos now.
Thanks everyone!
