uninstall iTunes 8.2 and replace with 8.1 with windows
Thefast1
Jun 5, 2009
vermont
does anyone know how to uninstall 8.2 and re-install 8.1...not with a mac
THANKS
shutter13
Jan 8, 2009
2,201
144
Go to youe control panel>Add Remove Programs
Uninstall. Then reinstall.
Thefast1
Jun 5, 2009
vermont
Yeeah i tried that, after reinstalling 8.1 and plugging in iPod it says, version is later than version installed please visit iTunes to download latest version and reinstall
shutter13
Jan 8, 2009
2,201
144
Try uninstalling, and uninstalling the Apple mobile device support, then reinstall 8.1.
vtec236
Sep 11, 2007
22
Colorado
Where can i get the exe or dmg for 8.1.1? tried search with no luck
scotty1
Oct 15, 2009
If you have any trouble uninstalling and reinstalling iTunes you will want to check out this link...
It can keep you from going nuts and is worth it!
There are some very positive comments at the end of the post be sure to read: http://zardozz.com/zz/2008/04/how-to-completely-uninstall-and-remove-all-traces-of-itunes.html
It can be found here: http://rockbridge.payloadz.com/productdetail.asp?Id=514696
Worth taking a look if all else fails or you just want to fix the problem without doing a lot of research and wasting a lot of time fixing your registry area!
