unlocked 1.0.2. iPhone. ringtones?
SoleAddict23
Sep 16, 2007
46
how do i get ringtones on a unlocked 1.0.2. iPhone? do i go about the same way with the samesong app on a 1.1.1. iPhone (NOT unlocked btw)?
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
I use ibrickr to put them on. Of couse you have to have a ringtone first. I use WavePad to cut the song into 25 seconds then Ibrickr to upload the ringtone.
SoleAddict23
Sep 16, 2007
46
ohh i used to do that on when i had the 1.0.2 firmware (not unlocked). but is it safe to use on an unlocked iPhone (tmobile)?
ibrickr works with an unlocked fone as well right?
thanks again. =)
Chris716
Nov 29, 2007
807
IL
i use adobe soundbooth to take the song down to around 30 seconds
SoleAddict23
Sep 16, 2007
46
i already have a program to cut the songs into 30 seconds. im just wonderin if its safe to use ibrickr on an unlocked iPhone under the 1.0.2 firmware? not sure if it makes a difference but its unlocked to work with tmobile btw.
