unlocked iPhone 3
Wing06
Dec 13, 2011
I have an unlocked iPhone 3G. My software version is4.0. If I update my software will that effect my unlocked phone. I'm very new to the iPhone.
iphonewarrior
13,847
699
Has your phone been unlocked via your carrier or by Ultrasn0w?
If it's been unlocked by your carrier you're safe to update your software. If you've used Ultrasn0w that means you've jailbroken, which in turn causes problems when you update the devices iOS. Unless you preserve the baseband you shouldn't update.
Thread moved to the iPhone Unlock section.
iphonewarrior
13,847
699
That means you're jailbroken. Updating your devices firmware will remove the unlock, unless the iPad baseband is installed.
