unlocked iPhone v 1.1.1 acting like iPod
fretos86
Nov 12, 2007
20
HI,
i got my new iPhone 3 days ago. its an unlocked iPhone running v 1.1.1 .
I installed customize and summerboard , and after i did some changes , the phone restarded and now the springboard disappeared and all i can see is a black screen saying , Ipod on the top left corner , showing the time in the middle ,battery top right corner. When i double click the menu button i go in ipod and the other thing is that i can still receive calls. Other than that i cant do anything since i don't see anything. I cant restore my phone because it will be locked again !
Thanks for helping in advance!
faseone
Oct 2, 2007
203
I don't know what version of customize u have and I don't use it but I read it has a hide apps feature look for that in the settings and see if its on....
hope that helps
Hondamaker
May 14, 2007
9,946
671
57
Fairborn, Ohio
HI,
Do a search on this or try to contact tinman so you can get a copy of the plist file. You put that file onto your phone and overwrite the one that's on there now and you'll get your icons and iPhone back.
edit: check here--->http://forums.everythingicafe.com/threads/updated-some-themes-iphone-now-thinks-its-a-ipod.14357/
