Unlocked Phone, No WiFi
Sep 22, 2007
Hey everybody i finally got my phone unlocked after countless hours of searching and i am stil having a problem.....
When i go settings i still cant click wifi it just says "No WiFi"
i have heard that i can restore but after i restore wont i have to unlock it again?
Please reply, thanks.
Sep 22, 2007
yes i hv wifi in my house, but i cannot open the options to view netoworks is my problem
it is just grayed out and says "No Wifi"
if i restore my phone will i hv to RE unlock it?
ciaran00
Jul 21, 2007
242
opticsoldier. While I was in the #iPhone channel I heard of two instances where an unlock removes some functionality. This seemed to happen on newer iPhones.
Either you will lose speaker
OR you lose wifi.
I urge you to check out the iPhone channel and ask around... I don't remember what the fix was.
oxs86.hu is the server
#iPhone is the channel...
A restore will not undo your unlock. I would not undo your unlock unless you have very good reason to do so. Here's the methodology anyway...
http://www.iPhonegoboom.com#restore
