unlocked virgin phone mod
stevea927
Oct 12, 2007
I have had my iPhone for about 3 weeks now and i want to mod it. I have fw v 1.1.1 because i updated it through iTunes. I did this because at the time i didn't want to mod it at all. Then i read some were that if your not unlocking your iPhone ( i have AT&T ) and are just installing 3rd party apps that you can uninstall the apps and return the phone back to the way it was before the mod. My question is would the phone be exactly like it was befour to the point you could bring it into Apple and request service on the phone and they wouldn't be able to tell you once had 3rd party apps on the phone ? Also could i uninstall the apps and update my phone to future fw with out aproblem ? Of course not expecting to retain the apps ?
akophone
Aug 1, 2007
300
There is an updated guide for downgrading from 1.1.1 to 1.0.2 for both platforms, which includes the baseband downgrade.
For OSX
For Windows
Compliments of the fine folks at MMI!
Good luck!
