Unlocking iPhone to use with AT&T other SIM?
NickT916
Jan 4, 2008
266
I asked at ATT if i can use my blackberry ATT SIM and just put it into the iPhone and use it, and i was told no that once i activate the iPhone it will disable the blackberry SIM.
If i unlock the iPhone can i simply put in my blackberry SIM and be able to use it?
I want to be able to try to learn the iPhone while being able to use my blackberry. Also if i get the date plan for the iPhone can i use it on the blackberry as well, or get blackberry data plan and use it with iPhone? or if i don't get the date plan for the iPhone i would have to disable EDGE and just use WiFi?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
You are complicating your life instead!:eek:
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
that's true that the Blackberry sim card will be disabled. Apple puts a new sim in every iPhone so they will know when one is activated. Once it gets activated, then Apple starts getting their funding from AT&T for their portion of the iPhone data plans.
Now you can remove the sim and put it in another phone and your second phone will work just fine. Your data will still be free (unlimited) and you will still have whichever amount of sms that you chose (200, 1500, unlimited) when you selected your new iPhone data plan.
YOu won't be able to use both phones at one time, but you can certainly swap the sim card between phones. I've done this many times with my other phones just to verify that they will work.
jjvaldez
Jul 3, 2007
2,615
33
Salinas, Ca
that is what i do when i go places that i think that i might break my iPhone, i use a old crapy nokia i got on craigslist for 20 bucks
yuuphone
Sep 26, 2007
86
Quick question, how do I get the sim card out? I know it's located at the top of the phone but I can't seem to open it...
NickT916
Jan 4, 2008
266
oh i was under the assumption that you cant use iPhone sim with the blackberry at all or any other phone for that matter. But if i can pull the sim from iPhone and put in blackberry and it will work thats great... would the iPhone have to be unlocked or jailbroken or anything?
Also to transfer all the names and phone numbers from blackberry to iPhone can i unlock the iPhone, then use my old sim card put it in the iPhone, transfer and then activate the new sim with iPhone?
