Unresponsive areas after replacing screen
Jun 21, 2014
Any idea on this issue? I replaced a cracked screen. Every cable is connected, however I'm thinking its an issue with a cable connection itself. Any thoughts on which cable would cause an issue such as this? I can moderately see the screen, can still answer calls, touch screen works, but not in corners (such as to change from ABC keyboard to 123 keyboard). Any help is appreciated!
Ledsteplin
Oct 29, 2013
4,823
987
65
Florence, AL
It seems that most times I see an image of a messed up screen, it's one I've never seen. There's a few I recognize, but not this one. If a new phone or taking it to Apple is out of your budget, then you have 2 options. 1. Take it to a reputable repair shop or person. They will charge you, but not as much as Apple. 2. Backtrack your steps and make sure all the connections are correct. Make sure the connectors are snapped on properly.
efuseakay
Nov 11, 2008
864
99
Also, where did you get the screen from? Some of them don't sell genuine Apple replacements. If it's a knock-off, you just may be SOL.
