Unresponsive home button
Jun 25, 2010
645
my home button is acting weird, most of the time it's fine, but with increasing frequency it registers a single click as a double click or no click at all, what are my options here? will Apple fix the button?
eye-Fone
Jul 5, 2008
1,024
14
Sunny, southern California.
Okay, well then call their support beforehand - they can be extremely helpful 9/10 times! Compared to other support lines, Apple's is great!
If they can't fix it, they will usually replace it, on-the-spot (assuming it is within the warranty period or under Apple Care).
...also assuming that they have replacement ones in stock (they generally use refurb'ed ones)
jordan79
Oct 27, 2008
24
Hi mine has started doing the same. Sometimes it works an sometimes not. Only started a week ago. Tryed double tap and it takes me to spotlight. 8 out 10 times it does this. Think ill have to change it for another one but everything else is fine on it.
Aug 27, 2008
Perhaps your backlight has dimmed and when you click your home button you are thinking it registered when in fact clicking the home button with you backlight dimmed only makes the backlight turn back to it's highest brightness and then you have to double click? Does this make sense?
jordan79
Oct 27, 2008
24
Yeah i know wot u mean but its not that. I have this thing were everytime i close an app i have to close it in the multitask too stright away so it doent have time dim really. But i see your point.
coop1701
Jun 30, 2007
899
114
43
Mine has been doing the same exact thing... But I do believe it's a software issue. Not a hardware one. I am tempted to take mine back. But I have noticed this. depending upon how I opened the App and what App it is. Seems to have a effect. Like in Email. i close out email with the Home button. It always works. If in the Ipod, then it takes me to multitasking. Some apps, if I opened them via Switcher. They do not register the button push at all.
I'm not entirely sure it's a hardware issue. Mine was fine on 4.0. then 4.01 was when I first noticed this issue. The longer I have been on it. The worse it has gotten. Specially flipping from one App to another. Like FB and Twitter.
Jun 25, 2010
645
good observation, I'll have to keep an eye on this
Mendo88
Dec 8, 2010
I've heard this is a popular issue affecting a lot of people. Can be very unresponsive and takes several attempts to recognize when I press it.
What can be done if anything if i take it into Apple.
RoofMonkey
Jun 21, 2010
8,867
2,047
I have read, in the forums here, that some people have had good luck with a Q-tip dipped LIGHTLY in alcohol. Run around the edges of the home button. I can not vouch for this fix personally as I haven't had a problem.
RoofMonkey
Jun 21, 2010
8,867
2,047
iPhone 4. Around a year and a half. It's insured but don't know what Apple would do about it
of you have an Apple store near by, make an appointment with a genius and have them take a look at it. They may replace it for you. Be sure to sync & backup before you go.
