Unresponsive portion of screen
The Apple
3,105
Indiana
Well I had been "working around" this problem for awhile, but I guess its time to get it fixed. The uppermost portion of the screen where the signal, carrier logo, and the battery level sit in that black area on the top, is unresponsive. That means that the back button does not work when using safari tipped to the side. It also means that I have problems using the Q, A, shift and the keyboard switcher button. I have reset and restored and nothing helps.
Any tips or suggestions on how to go about getting this fixed? I bought it at an AT&T store so I don't know whether I should take it back there, take it to an Apple store, or just mail it in myself.
15,385
1,089
I'd have a genius look at it at the Apple store.
SmartAlx
Jun 7, 2007
1,087
How shameful The Apple. I expect a zea lot to know how to search.
Jun 26, 2007
487
take it to an Apple or att store
pick your poison... jk
it should be easy to fix and shouldnt cost you anything because its under the warranty
Indy
Jul 29, 2007
2,921
39
Good Luck!
