Up dating my iPad 1
PDACPA
Jan 16, 2008
542
Plug your iPad into your computer and start iTunes. On the left side of iTunes your iPad will be listed about midway down. Click it. In the main screen window of iTunes it will show a picture of your iPad. Below that picture is a button that says "check for update." it will tell you if you are on the current version.
That being said, why not do some research on these forums and online and learn about your iPad. The "search" button is your friend. :)
Michael Baturin
Jul 11, 2007
1,751
244
34
South Jersey
I'm sorry I don't know what iOS is as I said I'm not technical
You will need to plug it into a computer and open iTunes. Then click on the iPad in the left hand bar. Then the iPads settings will come up. Right click the iPad and chose Backup. Then right click and chose Transfer Purchases. If you don't have your music in iTunes - I suggest first pulling it all off via a third party program like tansee iPad transfer. If you already sync to iTunes anyways or don't have any video/music disregard that step.
Once you have all your purchased music in iTunes and have completed the backup, Click iPad and then click Update towards the middle of the right pane. It will update your software now.
Sent from my iPad 2 using iCafe app
PDACPA
Jan 16, 2008
542
Google "iOS" and you will get the answer, but I will save you time. It stands for the operating system on your iPad. The software that makes it operate.
