Update American iPhone
Emorik
May 10, 2009
Ok difficult question. I have an american iPhone 3g 2.2 Jailbroken and unlocked. I used it with the T-Mobile. I moved to UK now and i have an o2 dim. It works perfectly but i would like to upgrade my iPhone. What can i do?
5,578
Restore to factory settings and update to 3.0.1. Then jailbreak with redsn0w and unlock with ultrasn0w.
You can back up you apps first with Chronus and PkgBackup, but that's not a requirement, it just saves you some time setting it back up.
1- Back up your app store and stock apps with Chronus
2- Back up your jailbroken apps with PkgBackup
3- Back up your contacts with Google or Yahoo if you don't have Mobile Me
4- Sync your phone in iTunes,
5- Update to 3.0.1 and restore to factory settings (not from a backup)
6- Jailbreak with redsn0w using the 3.0 IPSW (you will remain on 3.0.1)
7- Unlock with ultrasn0w
8- Restore your jailbroken apps with PkgBackup
9- Restore your stock and App store app settings with Chronus
http://www.iclarified.com/entry/index.php?enid=750
http://blog.iphone-dev.org/post/126908912/redsn0w-in-june
http://blog.iphone-dev.org/post/128573459/ultras-now
