Update Apps Drains Battery
RLK
81
Indialantic, FL
This morning I recorded my usage so I could track drainage. Then, on the 3g phone, I updated an app. That was the only activity I had with the phone. Later, I again checked the usage and it was up by 2 hours. I turned the phone off/on and now the usage again looks normal.
Does this happen to anyone else?
flabyboy
Jun 25, 2008
769
Minnesota
There are a few discussions about this topic in this and the software forum. Look for discussions about battery problems. I had this issue where my usage meter grew while the phone was asleep and my battery drained. I had the phone replced by Apple, but I think it is a problem with 2.1
6,682
49
My thought would be that the App Store is not releasing the connection. If you open the apps store and then immediately close it, chances are, if there is an update, it will still notify you. It might be possible that for whatever reason, the app store was either working over a bad connection, and kept retrying, or there was a problem with the protocol to release the connection when the store is closed.
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
I've noticed this as well. So what the best thing to do...force quit the app store when done?
psylichon
Oct 31, 2007
16,591
751
41
Philly
That's not a bad idea.
Someone in the jailbreak community needs to whip up a task manager...
