Update iTunes?
the PHDs
May 21, 2007
163
question,
am i going to need to do any sort of update for my iPhone to work with iTunes....
or it will just work?
Cantwait4iPhone
May 6, 2007
995
United States
I am sure there will be an update for the iPhone, for multiple reasons. They will need to make sure the iPhone will be compatible, and they will likely be adding a ringtones section. The list goes on, but I think you get it.
joe
May 5, 2007
1,113
question,
I would guess that there will be an iTunes update to allow it to recognize and work with the iPhone if the recent 7.2 update doesn't already. Otherwise, you shouldn't need to do anything else.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
I'll bet 7.2 covers everything for iPhone. All you need is an iPhone to hook up to your computer and you'll get some new tabs to select.
