Update to software 2.0 without Sync?
Link971
Aug 21, 2007
9
Ok, here's my problem: About a month and a half ago, my laptop's hard-drive crashed. All my information, kaput. To make a long story short, is there a way for me to upgrade my iPhone to software 2.0 without syncing to iTunes? I'm afraid to even connect my phone to another computer, since the first thing it's going to do is erase all the information on the phone and replace it with what is on the computer. Any ideas?
Saverino
Jun 1, 2008
4,480
92
Burbank
I think you're going to have to sync with iTunes. I don't think there's another way to get it.
Sorry :(
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
If you do a quick search, there are several tools that will pull your info from you phone (music, etc)... I don't remember off the top of my head, but they do exist.
dcom
Aug 7, 2007
1,421
Suwanee, GA
If your phone has all your information but you have another computer where you've installed iTunes but never synced your phone to it, you can go into the Preferences of iTunes, select the Sync option and disable automatic syncing of all iPods and iPhones. That way, when you connect the phone, it won't try to sync it unless you click one of the Sync buttons within the iPhone device tabs. You can even turn off individual items to be sync'd on each of the tabs when you click on the iPhone.
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
but the new update wipes you and you start from scratch.
dcom
Aug 7, 2007
1,421
Suwanee, GA
Good point. You will lose your music and videos during the upgrade so if you're not on your computer with your iTunes library, you won't be able to get your music back.
marklynn70
Jul 18, 2007
133
Oldsmar, Florida
www.myspace.com
Just be sure and perform a back up when ever you do hook back up to a PC, then perform firmware update, then back up your phone data with your the previously saved back up. Everything should work out.
