Updates
Trina723
Dec 23, 2011
Should I update apps if I have a1st generation iPad? How can I turn off update alerts?
showguy
Dec 2, 2007
769
Long Island, NY
If apps show up as being available for updates they should be updated. In regard to shutting notifications off you can shut them off totally or individually. SETTINGS/ NOTIFICATIONS.
showguy
Dec 2, 2007
769
Long Island, NY
If your talking about the alerts that pop up on the home screen you can shut them off like I explained above. If you talking about the App Store alert icon, like the writer above explained it can't be deleted.
  • Like
Reactions: applejailescape
Lon
Jun 5, 2010
2,946
132
Alaska
If your talking about the icon that looks like this (see attached) then I don't think you can get rid of the red icon in the corner , there may be a Cydia tweak but not 100%?
There is a tweak called Update Hider, which works quite well.
