Upgrade 1.0.2 or 1.1.1 to 1.1.2 Unlocked
Chris716
Nov 29, 2007
807
IL
Since ive been asked a lot about this lately here you go
For both Mac & PC's
First, download the following Firmware files
Firmware 1.0.2
Firmware 1.1.1
FOR 1.0.2
I'm assuming you have already by-passed and jailbroken your iPhone
and also have Installer.app
Make sure you put Auto-Unlock to NEVER
1. On Installer, go to the sources tab at the bottom right hand corner of the screen and click Edit and Add
Add the following: http://I.unlock.no Once it's done refreshing sources, go to the Install tab and scroll to Unlocking tools and then Install the 03 xx Revirginize application. After 3-5 minutes, your iPhone, previously unlocked will be Re-virginized. You may now safe upgrade to 1.1.1. To do so, on iTuneshold shift(PC) or option (Mac) and choose the 1.1.1 Firmware file you have downloaded earlier. Now you may follow the steps for 1.1.1
FOR 1.1.1
If you have already by-passed activation, jailbroken and have Installer.app installed on 1.1.1, continue to step 2
1. Jailbreak into iPhone using Jailbreakme.com.
http://iPhone.ranova.org/21.shtml
(Don't proceed with unlocking, it's only a waste of time)
2. Once jailbroken, go to Installer and install Oktaprep from Tweaks 1.1.1.
3. Go to iTunes and update to 1.1.2
4. Once the firmware is updated, downgrade back to 1.0.2 via DFU mode or special restore mode by holding home and sleep buttons for 10 seconds and then releasing sleep while continuing to hold home. iTunes will recognize iPhone in restore mode. Hold Shift (PC) or Option (Mac) and press restore, and choose the 1.0.2 Firmware file
5. Once done, Error 1013, no problem. Close iTunes and use the following to activate and jailbreak:
PC: AppTapp http://www.nullriver.com/~adam/AppTappInstaller.exe
Mac: Independence http://code.google.com/p/independence/
Independence will kick iPhone out of recovery mode by just opening the application.
6. Download Anysim 1.2 here . Unzip and rename the folder anySIM.app and then SSH into the applications directory in iPhone. (Username: root Password: dottie) or password could be alpine or whatever you changed it to
7. Run Anysim 1.2 and once unlocked, restore your iPhone via DFU mode/special restore mode and then connect to iTunes and the restore to Firmware 1.1.1 (same steps as above)
8. Once done, Error 1015, refer to step 5
On PC, just choose the 1.0.2 Firmware on AppTapp
9. Jailbreak 1.1.1
(DO NOT UNLOCK, iPhone WAS ALREADY UNLOCKED AND WILL REMAIN UNLOCKED)
10. Refer to Step 2
11. Upgrade to 1.1.2 on iTunes
12. Download the jailbreak softare for 1.1.2
http://sharebee.com/75991537 OR http://conceitedsoftware.com/iPhone/1.1.2-jailbreak.zip
***On Windows, double click on windows.bat, on Mac, double click on jailbreak.jar
follow the on-screen instructions
Once done, you're iPhone should have an unlocked iPhone with 1.1.2 Firmware.
Chris716
Nov 29, 2007
807
IL
did anyone need this if not ima have it deleted...
SoleAddict23
Sep 16, 2007
46
i might need this. leavin a response so i wont forget it.
thanks!
