Upgrade from 1.1.4 to 2.0? :)
Jan 12, 2009
Hi everyone, I'm new here so please go easy on me :sick:
I discovered an awesome theme at DA(http://bency.deviantart.com/art/StarCraft-II-iphone-Theme-108920089) and just had to fix it since
I'm an old Starcraft fan/nerd/YouNameIt. I found out that my iPhone version was too old for the application (winterboard) to be able to use it, and now. I've been searching for quite some time are an easy installer so i can upgrade it from 1.1.4 to above 2.0.
Could anyone help me out
? =3
What program did you use?
Picazzo
Jan 21, 2008
2,808
Copenhagen, Denmark
? =3
Go for 2.2 and use the guides here!
ess_bee
Dec 16, 2008
152
UK
is it possible to downgrade from 2.2 to 1.1.4?
Ive been reading up and firmware 1.1.4 seems to be the don of software! was 1.1.4 really that good? Im guessing there was plenty of downloads for it on cyd and installer?
Picazzo
Jan 21, 2008
2,808
Copenhagen, Denmark
Don't downgrade...I have used 1.1.4 on my V1 iPhone, and it wasn't that great! 1.1.1 rocked in the good old days, but now with AppStore etc., I wouldn't downgrade if I where you!
ess_bee
Dec 16, 2008
152
UK
Thanks for the heads up
Ezekiel2517
Sep 20, 2007
693
? =3
woah, thats a pretty sweet theme! thanks. :cool:
Jan 12, 2009
After upgrading to 2.2 you need to re-jailbreak ...still follow these guide here on EIC ore the links I gave you! :)
Can i still update it from a jailbreaked 1.1.4 to the normal "un-jailbreaked" 2.2
or do i need to erm... "Factory reset"(?) it to 1.1.1 and then go to 2.2?
In other words, Un-jailbreak it, then "factory reset" it. Then go up to 2.2 and from there jailbreak it?
Picazzo
Jan 21, 2008
2,808
Copenhagen, Denmark
1. Update your iTunes...I guess you have done this ;)
2. Connect your iPhone, and hit "Restore" in iTunes for version 2.2
3. After that you just follow these guide and jailbreak your iPhone
Now you got 2.2 and you got to re-install all the JB applications again. You'll also have AppStore - I'm pretty sure you will use this one!
If you have any question about this - just ask! :)
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
Whoa. Just hit update. You may have to end up restoring anyway, but try to update first. That way you won't have to resync all of your media again. That will place you on a fresh 2.2 stock iPhone. from there decide if you want to jailbreak. I've jailbroken every single version since day 1. I'm running stock now. I just didn't use anything that was from jailbreaking. The appstore has pretty much killed any good apps from cydia/installer, imo.
Jan 12, 2009
Erm as i continue to update my iPhone to 2.2 and fixing some settings, some AT&T crap came up, where i needed to enter my phone number and crap. well the thing is that the iPhone is american, but i live in europe, and have a phone account from there. should i still write in the information for At&t?
Picazzo
Jan 21, 2008
2,808
Copenhagen, Denmark
I'll guess you have to unlock + jailbreak your iPhone if you're not on AT&T account!? If you unlock your iPhone you can then use any SIM card from any country!
Jan 12, 2009
Ah, okey sure.. But as i've understood it.. there's no solution to unlock / jailbreak 2.2 yet, is that correct? (for pc that is)
