Upgrade help
Reisdennis62
Oct 11, 2010
214
Livingston, Ca
So my sister and I are on the same family plan on AT&T and we both have iPhones.
I unfortunately can't upgrade until July 2013 but she can and has offered to let me use her upgrade.
My question is will I be able to do that? Preorder the iPhone 5 under her name then when I get it go to the AT&T store and ask for a nano sim so I can place it under my number,
Any knowledge is appreciated!
Real Madrid_MUFC
Girdler
Aug 1, 2012
283
44
30
Yes you can do that. Once the phone is received it will have a SIM card with it, but that is for your sisters phone. You would need to have her contact AT&T and activate her old SIM(or prevent the nano from being activated). Then, you will go to the AT&T store and request a Nano SIM. Once you have a Nano SIM for your line, put it into the iPhone 5 and go from there.
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Actually, the iPhone 5 will come with a Nano SIM already. All they will have to do is have AT&T transfer the upgrade to her line and number, and then she can activate the iPhone 5.
jfleming01
Apr 29, 2009
150
Same situation (only upgrade is from son who has a dumb phone will I have to go to the store with the preordered phone or can AT&T make switch remotely.
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
I was told they can transfer the upgrade to another line and number over the phone in their system. Basically all they have to do is switch the IMEI codes.
trido
87
I think I follow this as I am doing same thing via Apple.com.
So in his case the iPhone 5 will come with a nano sim HOWEVER that sim included will have HER phone number on it?
SO he will not want to even turn that phone on right?
And go to att and get a new nano sim and have his number on it right?
If this is all correct than I was told wrong I was told all this can be done by just call ing ATT but that cant be if in his case that iPhone nano sim with have her number on it?
Or am I wrong does the sim stay blank UNTIL activated maybe?
thanks
trido
87
so the installed nano sim stays blank unused till phone activated?
thanks
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
thanks
Technically the iPhone 5 will be for her account, you're right. But until she activates the iPhone 5, nothing will change. As I was told, DO NOT activate it yourself until you call and they switch the numbers in the system, then all will be well and her iPhone will have her number on it. No need to get a new Nano SIM.
Girdler
Aug 1, 2012
283
44
30
thanks
If the upgrade is through her phone, then the SIM card included with the order will be tied to her phone. He will just have to get a Nano SIM for his number and she will continue using the phone and SIM card that she currently has.
She will just have to provide AT&T with the number on the SIM card and the IMEI number for the phone.
He will provide AT&T with the IMEI number for the iPhone 5 and they will obviously know the Nano SIM information, because they will be giving him one.
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
He will not have to get a new Nano SIM. They change the information in their system and all is well. I talked to many stores today and AT&T and Apple about it. And I've done cross transfers before.
Girdler
Aug 1, 2012
283
44
30
They should be able to use the Nano SIM that comes with the phone, as long as it is never activated. However, if for any reason the phone is turned on and activated(either by mistake or purpose to test the phone) then they would have to get a new Nano SIM because it would be tied to her account. I'm just wanting to set the expectation of needing a new one, just in case anything does happen.
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
Anyone doing cross transfers, just do not activate it. Call AT&T or go there and ask them to transfer it to your phone. Turning the phone on will not activate it, you have to call the number that it will give you on a piece of paper in the box.
trido
87
Ok I might be confusing this somewhat original poster wants to use his sisters full upgrade but he wants the new iPhone 5 for himself on his number.
So he would call ATT or go to att store say my sisters line should be two year upgraded however i would like iPhone 5 on his line.
So i am thinking since he never turned on his sisters iPhone 5 he can call in to att tell them sim number as it is still blank unactivated and they will use it for HIS numner right?
You say her iPhone will have her number that really is nothing has changed as far as her older iPhone except her line now has been upgraded and HE now has the new iPhone 5.
Main thing I like to know if the un activated nano sim can be used on a diferent phone number than what Apple ships it for as long as not activated?
thanks
MoneyMaker79
Dec 15, 2008
5,386
340
30
Pensacola, FL
thanks
I'm confused with the question you asked, but yes. Let me explain. I am doing the same thing she is doing, the original poster. I have done this before. I upgrade my mother's phone line with the iPhone 5, both her phone and mine still work obviously. Then when I receive iPhone 5 I immediately go to AT&T or call them and they switch over the information so MY iPhone 5 will have my number. If I don't do this, and I activate it, it will have my mother's phone number attached to it.
