upgrade or downgrade ?
foamtech
Oct 30, 2007
39
maybe someone could help me.I got my iPhone on ebay 2 month ago unlucked (i geuss 1.0.2 ),it's working fine here in Europe with T-mobile . I know there is a launcher ,unluck, installer ,icons on the screen ..but not sure what to do .. do i need to upgrade and if so can i use the installer to do that on wifi network ?or do i need to download all that stuff to my pc ? thanks 4 taking the time to read this ..
termleech
Sep 7, 2007
1,154
McPherson, KS
If you want to install 3rd party apps, you can use the installer to do it.
If you are talking about "upgrading" to the 1.1.1 firmware, you need to make sure you re-virginize your phone before upgrading then you can re-unlock the phone. Search on the boards a bit if you are interested in that.
foamtech
Oct 30, 2007
39
so if i verginized iPhone ,i will lose all the apps that's in right now ? and i will need to re unluck it by downloading form web ? did i get it right ? please explain thanks
termleech
Sep 7, 2007
1,154
McPherson, KS
Revirginizing the phone = relocking it. It means restoring to the original baseband in order to upgrade.
If you restore then you will no longer be jailbroken and you will have to re-jailbreak.
