Upgraded to Leopard, can't find iPhoto
iphonewarrior
13,847
702
basically just upgraded to leopard, and i can't see iphoto anywhere, i backed up all my stuff and formatted the HD and put leopard on.
my phone has all my pictures on and i've put all my pictures back on to my laptop but there just in a folder on my desktop, i know that when i sink my iPhone i'm going to lose them all
any help?
thanks
Eragon
Jan 8, 2008
3,056
51
Frederick, MD
When you say you can't find iPhoto, are you referring to the icon on your dock, or have you gone to your applications folder?
Marianne
2,326
29
Massachusetts
marianneschultz.com
iphoto doesn't come with leopard, iirc. you'll have to load iphoto onto your mac using the disks that came with your mac, or use any other ilife disks if you've purchased a new version since then...
iphonewarrior
13,847
702
right then i'm stumped because i had to format my HD before i installed leopard because i had major issues with tiger and i haven't enough life left to explain what went wrong.
is there anyway of getting iphoto without paying for it?
thanks
iphonewarrior
13,847
702
problem solved, free and easy and i've walked away with a nice (free) copy of ilife 08buzzing!
