Upgrading from 5.1 to 5.1.1
warren nunes
May 28, 2012
I recently purchased an iPhone 4s (turbosim) V5.1 and i would like to jailbreak it and upgrade it to 5.1.1
Can anyone explain or show me how can i do it ?
Would appreciate the help!
Thanks in Advance
CamXCollins
Jun 4, 2010
280
To upgrade your 4S to 5.1.1, just plug it into iTunes on your computer and it should automatically check for iOS updates. If it doesn't, just click on 'Check for updates' and it should come up.
As for jailbreaking it, just go to http://absinthejailbreak.com/ once you have completely updated to 5.1.1. It's an incredibly easy process nowadays.
warren nunes
May 28, 2012
CamXCollins .. i do not have a factory unlocked iPhone 4s ..​
Im using a turbosim on it ..​
If i upgrade it to 5.1.1 manually .. i believe it would get stuck on the activation mode..​
I am currently using v 5.1(9B179)
Modem Firmware: 2.0.10
