Upgrading process Lion
gadgetgw
Aug 12, 2008
9
Geelong, Vic, Australia
Does the upgrade just apply over the existing OS-X (Snow Leopard) or is it a fresh install and I need to re-install all the apps again.
Oct 2, 2009
3,550
New Jersey
www.abelgancsos.com
it's actually pretty simple, you get the cd, pop it in, turn off, turn on, boot to cd and upgrade. or you can upgrade without the cd boot up, but 2 things to be aware of:
1) lion tends to crash, at least the one that i was testing.
2) to save space on your hard drive, it's better to backup your docs and do a clean install.
Zanthe
#apple
Aug 9, 2007
2,638
323
CD? I didn't think there is a CD option.
15,385
1,089
dude, if you obviously haven't done the upgrade, don't give out instructions.
15,385
1,089
just did an upgrade. had a few bumps to iron out, but nothing huge.
15,385
1,089
had to reinstall iTunes 10.5 beta, had to update my mouse driver, and my eSATA card drivers are not compatible.
To be honest, I'm not really digging the iOS-influenced features. I guess they may be useful on a macbook, but I think they're just superfluous in a desktop environment.
patrickj
Sep 2, 2007
6,221
445
Austin, Tx
ipadinsight.com
Oh, I could see that being the case. You can turn them off if you want though right? Or most of them anyway?
5,580
Are iTeleport and AirVideo working okay for you?
5,580
Download just finished. I'm copying the file to a flash drive so I can install it on my MacBook after I install it on my iMac since the file will be deleted after the install. I'm also going to burn a bootable disk with Disk Utility really quick before I install it so I can do a clean install at some point if I need to.
http://osxdaily.com/2011/06/08/create-burn-bootable-mac-os-x-lion-install-disc/
Tinman
4,334
183
Aridzona
My upgrades all went perfectly. Pretty slick.
I did make a bootable USB stick for it in case needed. I'm keeping my air's OS stick and will just keep the other with Lion just in case I want to go back to SL.
I am getting more and more into mission control. I used spaces extensively and this seems to complete the picture.
I will say that smart zoom with my magic mouse on the mini was annoying as it was too easily inadvertently activated. Had to disable it, at least for now.
Michael
15,385
1,089
Well most of them aren't intrusive at all (like launchpad, which is truly useless unless i'm missing something). The only thing I had to actively disable was the silly reverse-scrolling.
