upgrading to 1.1.1
noho_2003
23
I have Pick Your Plan (GoPhone) and I'm still at 1.0.2 with AppTapp installed and some changes made with iFuntastic. Now I would like to upgrade to 1.1.1... What process should I follow in order for the upgrade to be as smooth as possible?
There are so many things online (Independence, Jailbreak etc.) and I'm confused.
greenjbhsd
Jul 13, 2007
571
For starters I think the general consensus is do a full restore of 1.02 before moving forward. Once you do that you can downgrade to 1.1.1 and it *should* go smoother. From there you can leave it stock or use something like this to get you the rest of the way (which I am not brave enough to try yet):
http://www.slovix.com/touchfree/
