Uploading .mp4 files to iTunes
Graham222
Mar 14, 2009
Can anyone help with this please? I can't find a way to upload .mp4 files to iTunes so I can sync with my iPhone and get them onto that?
styfle
Mar 31, 2008
3,381
I think the word you're looking for is importing, not uploading. File > Add to Library should work or right click the video and open with iTunes.
Secondly, you need to make sure the video is the correct format to even play on the iPhone such as h.264 encoding and whatnot.
Graham222
Mar 14, 2009
Now from iTunes to iPhone
Thankx! movies (.mp4's) are now in the iTunes library but can't get them onto the iPhone. I can't seem to be able to drag and drop. Any other ideas?:)
15,385
1,089
you probably need to convert them for iPhone compatibility. Go to Advanced->Create iPod or iPhone version.
15,385
1,089
are you manually managing your music/videos, or do you "sync"?
15,385
1,089
in that case, you need to go to your iPhone options screen, and select the videos you want to sync.
like so...
