USB port problem
ndwgolf
Nov 8, 2007
88
Phuket Thailand
My MBA has stopped recognizing my mini SD card when I plug it into my MBA..... when I plug in a Thumb drive it shows up straight away but it wont see the SD card......... any ideas how to reset the USB ports or a way to fix this problem?
Marianne
2,326
29
Massachusetts
marianneschultz.com
Does the miniSD card work with any other computer? If other devices work in your MacBook Air's USB port, it could be that the miniSD card has just died.
ndwgolf
Nov 8, 2007
88
Phuket Thailand
I do not have access to another computer right now but the SD card works fine in the Blackberry
ndwgolf
Nov 8, 2007
88
Phuket Thailand
How are you connecting it to your MacBook Air? Through a card reader or while it's inserted in another device like your Blackberry?
card reader............ I will buy a new card reader today and see if that helps
