USB port towards a iTunes icon?
bkid97
Jun 27, 2007
11
ok i just downloaded 1.1.3 and i i powered off my iPhone and turned it back on... and now it shows a usb cable going towards an iTunes icon and then it says slide for emergency and i do that and its goes to an ermergency call! someone please help me this is starting to scare me thanks for anyone who can help me
kimo
Aug 7, 2007
169
Did it completely install (update firmware, etc), you may need to hook it backup to iTunes to let it finish. Make note this may take a while so sit back read a book or eat sandwhich and wait until it is done.
petalmom
Jun 30, 2007
494
I agree, I don't think you completed in the install.
bkid97
Jun 27, 2007
11
well that was weird......iTunes iPhone said to try to reconnect your iPhone or it said that it couldnt read the sim card and i need to go to att to replace it for a new one so i just switched ports on my computer and now it works hmm im not exactly sure what happened because i always used the same port on my computer......hopefully it doesn't happen again thanks anyways for your replies
