Use Cellular Data Settings
Nrevezzo
Apr 15, 2009
104
23
Canton, Mi
I thought the "Use Cellular Data" settings was supposed to limit the use of cellular data for various components like music.
I have the music setting off but it still allowed listening to iTunes Radio over the LTE connection. I expected that it would tell me that I need to change the setting for it to work. That's the way it annoyingly works for Notes.
Fortunately I didn't go over my data plan limit.
I think this is a bug.
hifly
Aug 7, 2013
LTE switch should be toggled off after you turn the "Use Cellular Data" off.
LTE is cellular data so it should not be possible to use LTE when you've turned off cellular data.
Ledsteplin
Oct 29, 2013
4,819
985
65
Florence, AL
Also, Verizon told me they don't count data used while on wifi against your data plan amount. Such as when cellular is turned off but still shows data usage. So you might check with your carrier on that.
Sent on iPhone 5 using iCafe app
