Used TV's
iAlex
Jun 27, 2007
21
Was wondering what was a cheap way to buy a hdtv for around 300 used.. in college and thats all i can scrounge.. i look up craigslist everyday but that doesn't cut it
any advice from anyone?
el31415
Jul 15, 2007
215
As for $300 for an HDTV good luck
Dell 20in LCD Monitor $247 (on special)
than you will need to buy and HDTV tuner or HDTV card if you have a pc
and use your PC as HD recorder
or get a Job that pays at least $100 a day work 3 day
will end up with 600 you can buy new 32 to 37 inch HDTV or HDTV projector
skiz420
Jul 28, 2007
371
Boston
if you have comcast in your area go into a circuit city and tell them you want to sign up for comcast high def and get the 100$ any hd tv.... you don't even have to end up getting it but if you have comcast you kinda have to to use it to its full capibilitys.. but when its rang through its no way signing you up just part of a promo we have going on... hope tha helps a little... OH and if you have AAA or friends with AAA and want you can get a cupon through them to save 10% off the cost of the tv also... if you need help just pm me
