used ziPhone to jail break and am having problems
tricker11
May 9, 2008
i was using ziPhone to jailbreak my phone today, and the message said that if it didn't work in 3 minutes to stop the process and retry. after about 10 minutes i decided to click stop and start over, only problem was the computer cant find my phone anymore and now my phone turns on but just has a buncha white letters.
am i fucked?
MundoGrande
Jan 26, 2008
155
Try putting it in DFU mode.
Connect it to your computer with iTunes open. Hold home and the top button and right when screen turns black to restore, let go of the top button and hold the home button. Hopefully iTunes will recognize it.
tricker11
May 9, 2008
thanks man.
anyone else got any tips.
24trepid
Jan 13, 2008
502
You should use iDemocracy..........
It's so awesome....
onyxxx6700
Oct 27, 2007
58
After this is done, do you restore?
I had the same problem.
MaverickC17
Dec 29, 2007
178
ZiPHone 3.0
1) Backup your contacts and calander to your PC or Mac.
2) Restore iPhone as new iPhone, stop it from syncing when finished.
3) Close iTunes
4) Open ZiPhone and select the button that says "Jailbrake" only. This will ensure that YouTube works. Should take about 1 minute.
5) Sync back with iTunes
6) Done
onyxxx6700
Oct 27, 2007
58
Now I was running 1.0.2 on Tmo before the screw up. Any good way to get me unlocked again?
P.S. Thanks for the quick response
onyxxx6700
Oct 27, 2007
58
Sorry, just read about reconnecting to ZiPhone again. Once I jailbreak only, do I get installer and run AnySIM, or is there a better way.
MaverickC17
Dec 29, 2007
178
ZiPhone 3.0
I am on AT&T. But I think that there is a "Unlock, Jailbrake, Activate" button on ZiPhone. Just make sure that you are on 1.1.4 when you run ZiPhone.
24trepid
Jan 13, 2008
502
To use ZiPhone, you have to upgrade to 1.1.4
And if you're not on AT&T, click the "Do It All" button.
It unlocks, activates, and jailbreak's.
24trepid
Jan 13, 2008
502
If you're on AT&T just click the "Jailbreak" button.
It puts installer on for 3rd party apps.
onyxxx6700
Oct 27, 2007
58
Thanks Mav,
Up and running on 1.1.4 flossing Tmo
onyxxx6700
Oct 27, 2007
58
Thanks so much.
I am up and running.
