User Agent Changer - Compatible with iOS 8
iphonewarrior
13,847
701
User Agent Changer is a new package in Cydia which allows the user to change the user agent of their browser i.e display webpages as if you were browsing from a desktop. The default is Chrome User Agent settings.
For example you can browse eiC from your mobile device as if you were using a desktop. This package is free and is available from the MMi repo. This package also supports iOS 6 and 7.
ring0_event
Aug 24, 2010
216
Thanks for the post; that's another tweak I like which now works on iOS 8.
