Using a Blackjack SIM card w/ the iPhone
Sep 16, 2007
Hey guys, I'm thinking about getting an iPhone but wanna make sure I can do what I want. I have a Samsung Blackjack right now with Cigular, now since AT&T (Cingular) are the only people to sell the phone will I be able to purchase a iPhone and use my existing sim card? Will I also be able to have the same functions, I have an Unlimited Data plan right now with cingular.
Thank you
jnowaczyk
Sep 7, 2007
117
Michigan
www.gsmunlockonline.com
well yes and no if you activate it throu iTunes no you can use your same number and get the 20 dollar unlimited plan...
now if you are going to hack it and unlock it then prob yes im am not 100% sure you won't get cought as you are a AT&T customer
but since you are a customer you should just activate it throu keep your number and just do the 20.00 data plan good luck to you :)
