Using an iPhone overseas?
MNJON
Nov 21, 2007
164
9
Minnesota
Is it possible (with an unlocked iPhone) to take out my USA sim card when I land in Moscow, and install my Russian Sim card and be good to go? I know that some quad freq. phones are supposed to do this, but I don't know if the iPhone would do it or not.
Thanks!
baluvee
Oct 16, 2007
well that is what jail-breaking,unlocking activating is all about.search the forum please
apercele79
Jul 2, 2007
34
i used mine in romania last month with a romanian sim
so chances are you will be able to use it as well if your phone is truly unlocked
good luck
SkyyBoy
Jul 4, 2007
131
Hawaii
one question,
with an unlocked iPhone (either iPhonesimfree or anysim), do I need to bring my laptop for anything? when I switch SIM cards, do I need to use iTunes to "re-activate" the iPhone with the new SIM card? or, can I just pop in the new SIM card (configure the GPRS settings) and go? I would prefer to leave the laptop at home.
apercele79
Jul 2, 2007
34
if it's unlocked, you don't need to re-activate it
the phone should be activated and unlocked for all networks
Chris716
Nov 29, 2007
807
IL
yes if its unlocked you can use with any gsm provider. And no you wont need to activate it if you have it already unlocked because its been activated already or jailbroken
