Using an iPod touch as a phone
iemploy
Mar 3, 2009
74
I just bought a new Ipod Touch 8gb for my wife for her birthday. I carry a 3G iPhone. I just heard that there is a program out there that lets you use WIFI and use your ipod touch as a phone? Is that true? If so, what do I do about a microphone?
28,365
5,507
It will work for VoIP on WiFi. There are Skype apps at the apps store. I think the headphones for the iPhone would work for a mic.
6,682
49
I use 2 different apps for that. Fring is (or was, don't know if they started charging) Free app that supports IM and Skype.
Infinite SMS was 99 cents and uses a Gmail account to SMS people for Free over Wifi (not free to the phone user, but is to someone who has the app as well.)
These are work arounds, and technically can only be used one at a time. Also, both app need to be running (not at the same time) to receive anything. Infinite SMS however, does queue the text messages for you to see the next time you launch the program.
iemploy
Mar 3, 2009
74
Thanks for the help.
PepeRB29
Mar 21, 2008
1,500
8 mile
i believe truphone is another app that allows you to talk free to other truphone users. check it out in the app store, i have it installed but have nobody to truphone with :)
Skol312000
Dec 8, 2008
619
N
Skype is your best bet...
u might have to jailbreak in order to let apps run in background for when someone is trying to call u, u always have to e connected to wifi in order for communication, there is a mic u can buy for 15$ or u could use theiPhones headphoes, they have a mic on the
also...
iemploy
Mar 3, 2009
74
Thanks for the info.
