Using Apple Maps without data connection
AppleMicrosoft
Nov 21, 2010
54
I've recently purchased an iPhone SE and have started expermienting with turn-by-turn navigation. I've read that you can avoid using up your data plan if you chart out you trip ahead of time. The route information apparently stays in memory.
Does anyone know how you would have to chart out the route in order to capture sufficient details in memory for turn-by-turn navigation? It seems to me that the latter requires quite a bit of map detail. Would you need to (for example) pan through the whole route at a particular zoom level?
I'm not sure if it really matters, but I'm using voice navigation.
Put in your destination while your on WiFi, start navigation and then disable data. It won't find alternate routes or alert you with traffic problems, but it will guide you to your destination with the cached maps. Mine always continues to work when I'm in no-signal areas. This is because it caches the maps when you first add the route.
AppleMicrosoft
Nov 21, 2010
54
From experimentation, if you choose one of three routes to a destination, Apple Maps will guide you along that route without cellular data connection turned on. If you deviate from that route because you prefer another route, it wil persistently show that it is recalculating, but never actually do it. It has the map info to show where you are, but apparently, the intelligence to recalculate the route is not resident on the phone.
AppleMicrosoft
Nov 21, 2010
54
I also found that the direction in which the car was facing was not properly depicted on the map until I started moving. I find this understandable, as the phone itself was not oriented directly facing forward. The orientation of the phone depends on where it is mounted, and how it is angled for best visibility by the driver.
P.S. Odd that I cannot simply edit my last post to add the above paragraph, instead of creating a whole new post.
Ledsteplin
Oct 29, 2013
4,853
1,000
67
Florence, AL
What issue did you incur trying to edit your post.
