Using international SIM Card?
bigmac
Jul 13, 2007
110
Los Angeles
Greetings all!
In the near future I may be traveling to Asia, and S. America. iPhone has a Sim Card feature, however, I am told iPhone is designed not to accept foreign SIM cards. I have three questions:
  • Is it true?
  • Has anyone used a foreign SIM in there phone?
  • Have my hacker friends found away around it?
Thanks for all the posts, b/e everyday I learn something new here... :cool:
coop1701
Jun 30, 2007
899
114
43
Greetings all!
  • Is it true?
I would say no..., If it was a international AT&T Sim card like I had in my Last Razor phone. That may work. But any other carriers Sim card won't work.
I have heard of people hacking it, but not sure how successful they've been.
Napoleon Dynamite
May 20, 2007
103
30
Turin, Italy
www.connessionegratuita.com
There are two ways to use the iPhone abroad:
- Calling with Roaming plans, but it's a non-sense
- Buy a Turbo SIM, hack it to be used in the iPhone and activate it with the carrier of the country you'll go
bigmac
Jul 13, 2007
110
Los Angeles
I have searched the forum, and unable to find anything on this 'turbo SIM'. How do I go about hacking it?:cool:
cobalt24
May 31, 2007
49
The "hacking" step is lost on me. Where are there instructions to do this? Is it all available on their website?
Napoleon Dynamite
May 20, 2007
103
30
Turin, Italy
Turbo SIM costs $80 at Bladox’ store, although at the moment they’re experiencing a huge load of orders, so delivery will take longer than usual.
Here the instructions
1. use with A card to get IMSI, ICCID - go to menu Apple Saft->Show to see values (you may write it down), then Apple Saft->Set
2. use with your card
So no cloning, reader, anything else is needed.
First, your phone must be activated (with the AT&T SIM), jailbreaked, and with SSH and vim.
- Download the port of Bladox utilities http://www.hackint0sh.org/forum/show…5&postcount=16 on your computer, extract it on your computer (you need the binary file turbo-app)
- Download AppleSaft 0.92 from Bladox (http://www.bladox.com/pub/Applesaft-0.92.tar.gz)
- Turn on your phone with Turbo SIM + AT&T subscription
- Disable CommCenter - ssh to your phone, vim /System/Library/LaunchDaemons/com.apple.CommCenter.plist add
Code:
Disabled
for example add it just after these lines, already present in the file
Code:
OnDemand
If you don’t like vim, you can do this modification on your desktop computer (iPhuc/iPhoneInterface getfile, modify the file, and putfile)
vim ultra light survival kit
i : insert mode
ESC : command mode (from insert mode)
dd : delete the current line (in command mode)
:w! : save (in command mode)
:q! : quit (in command mode)
- Reboot
- Copy turbo-app to your phone (for example in /opt/bladox)
- Copy Applesaft.trb to your phone (for example in /tmp)
- ssh to your phone, set the executable permission to turbo-app (chmod a+x
/opt/bladox/turbo-app) and run it with /opt/bladox/turbo-app /tmp/Applesaft.trb. It should take approximately 30 seconds and you shouldn’t see any error. Please panic if you see one
- Reenable CommCenter - ssh to your phone, vim /System/Library/LaunchDaemons/com.apple.CommCenter.plist and delete the lines you added previously
- Reboot
- Go into Settings/Phone/SIM Applications/Apple Saft and choose Set
- Turn off your phone
- Turn on your phone with Turbo SIM + your subscription and test
Enjoy :cool:
