Using iPad overseas
Linda
May 17, 2011
Traveling from Australia to say Europe or US are there many problems using IPad. I have a 64g 3G model?
Do I have to get International roaming like you do with the phone? And does that cover email?
iNinja
Aug 8, 2008
3,984
20
UK
You will need international roaming or pick up a local sim card but make sure your iPad is unlocked to that carrier.
If you have roaming it will cover all data.
imutter
Apr 4, 2011
5,941
754
Somewhere between DC and Baltimore.
It depends how long you stay and on your carrier. It is almost always cheaper for me to get a prepaid sim from a local carrier.
iNinja
Aug 8, 2008
3,984
20
UK
There are no such thing as prepaid sims for iPad AFAIK, you have to sign up for at least 30 days IIRC.
iP5
Sep 7, 2010
2,964
136
Toronto
Unless you cut your own uSIM. The ipad really shouldn't be using a uSIM.
Sent from my Desire HD using Tapatalk
iphonewarrior
13,847
701
You can get a PAYGO SIM for an iPad 3G. My mum has one ;)
PeteSoh
Sep 10, 2012
Singapore, Singapore
I've got a question here .....am from Spore & goin for holiday in e UK & considering bring along qn ipad for use there...would I be able to procure a prepaid #G card in e UK that will fit e Pad ?
Thanks !
Sep 12, 2012
I got an international Data plan from ATT. You can actually do it direct from your Ipad. Just go to Cellular Data and ADD DATA PLAN. You will see the International Plan Tab!
