Vacationing to Niagra Falls, will my iPhone work?
gulbane
Jul 15, 2007
84
I know the iPhone does not work in Canada. I'll be in Niagra Falls for 4 days and desperately need to ensure that I will have access to my email for these 4 days.
We are getting into very detailed semantics at this point, but Niagra Falls exists in both Buffalo, NY and Ontario, Canada. I think I will only be about 1 mile or less inside the Canadian border (I'm staying at a Marriott located right along the Falls)
Anyone have any idea if I will A) be able to make calls and take calls and B) be able to access the EDGE internet/Email?
Thanks!
brianlamar
Aug 6, 2007
85
Why wouldn't the iPhone work in Canada? as long as you have a GSM signal (Vodafone or O2 in Canada) than your phone should work fine. You will have to pay international roaming charges.
Niagara Falls is on the border though, so you still might be able to pick up an AT&T signal.
Marianne
2,326
29
Massachusetts
marianneschultz.com
like brianlamar said, your iPhone will work in canada but you could be on another cellular network while you're there. you should call AT&T asap and see what their roaming charges would be and plan what you'll do from there.
gulbane
Jul 15, 2007
84
Ok guys thanks!
Forgetting the International Charges for calls, do we think that the email/web ability to work?
brianlamar
Aug 6, 2007
85
Ok guys thanks!
Yes, that should work on whatever network you're on at the time, as well as WiFi.
