Variation of this button
knx2517
Aug 1, 2007
11
Can someone make a variation of this button in a darker blue? I am using a Blue color theme, but this baby blue button just isn't working out, I need it darker, basically like the blue in the blue battery.
im sure others are looking for the same.
ok so it wont let me upload it for some reason, I am looking for the "bottombarknobgray.png" aka the slider with the arrow. Just looking for a darker blue version.
SiLeNtKiLLa
Jul 4, 2007
134
Atlanta
Open the one you have in an photo editing software and change the hue of the color, and you should be able to get it darker, also you can do the same with all other modifications if youd like, instead of waiting for someone to create it for you, you can do it right then and there.
