Verifying lacking options
Overscore
Feb 15, 2008
20
Chester County, PA
Hi forum. Can anyone verify that the options I'm looking for just don't exist?
TCP/IP configuration for joining a network without DHCP
A way to view current TCP/IP configuration
A way to change message sort order in the mail app
A way to have the screen remain on when phone is charging without globally turning off screen lock altogether
A way to tell the phone to keep playing the (uncustomizable) TM sound every x minutes, n times. Same with voicemail.
A way to get it to play the new mail sound when I'd auto-receives an email while I'm. NOT using the phone
Thanks!
chrismmm
Dec 27, 2007
612
Gwinnett, Georgia
i blv almost all of your issues could be resolved in this forum and with ther personnel and personalities here.
for wifi. to detemine your ipconfig, go to settings, general, network, wifi and it should list your ip assigned. this will only display your ip if you are attached to wifi network...
good luck
