Verizon data?
Buc0727
Mar 13, 2012
32
32
Texas
Does the lte data on Verizon waste fast cause I have unlimited on 4s n they said it works the same help me out n tell me data usage y'all go threw please so I can decide witheR to get the iPhone 5 or not
You'll need to look at your past usage and see how much you data usage you average per month. Then you can choose a data plan that will work for you.
There is a loophole to keeping Verizon unlimited data when you upgrade to the iPhone 5. A family plan with a dumb phone that is eligible for upgrade is a prerequisite. Let me know if you're interested
No, you upgrade the dumb-phone line to a 5 with a 2GB data plan and then switch the phone to your line after you receive it. Then you can cancel the data plan on the dumb-phone line since it can't use it.
It sounds like you'll be fine with a 2GB plan if you don't want to do that. LTE doesn't use more data, but it loads content faster so you might visit more web pages, which is more usage.
