Verizon iPhone 5 showing incorrect time?
jetson22
Jan 15, 2009
78
I have a new iPhone 5 and on the Verizon network. The time randomly changes and is incorrect more than correct. There is no set amount that it is off , 2 hrs, 11:36 etc. Called Verizon and they sent me to Apple. So last Friday I did the appointment thing and they did a complete restore. It worked great until I walked out of the mall then wrong time a gain. I went back to Apple last night and they gave me a new phone. Then this morning I woke up (late for work) the clock was wrong again thus affecting the alarm. Just called local Verizon and they said sorry but would have to live with it. WTH?
jetson22
Jan 15, 2009
78
I was on the phone with Verizon this moring for an hour. Tried removing clocks, manual set etc and only corrects for a little while. So they had me do another hard reset, again worked great for about an hour.
ivantwilliams
Jul 14, 2009
1,546
218
Curious, are you using WIFI? I bet the antenna is simply connecting to a tower that is simply 'off'. You're not close to a different time zone, are you?
psylichon
Oct 31, 2007
16,591
751
42
Philly
Try turning off location services for setting the time zone. Settings/Privacy/Location Services/System Services [at the bottom]\Setting Time Zone. This also saves battery.
