Very Important
brandonb
Dec 15, 2007
9
My mom got me a computer and all my stuff in iTunes is on hers how do i transfer it?
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
You want to move the music and video from her computer over to your new one? You can transfer it through a network connection, burn a cd on her computer and transfer it over, get a thumbdrive and move it over, etc.. If that is not what you mean then can you explain a bit more?
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
You probably won't be able to put all your music on a CD (700 MB), but if you pick up a 4GB Flash Drive, it will probably fit.
Usually, the iTunes music is stored in the C:/User/Music folder. On my computer it is C:/User/Music/iTunes/iTunes Music
I just copied the iTunes Music folder to my flash drive and then pasted it on my new computer and it worked fine.
Morval
Oct 23, 2007
101
Buffalo,NY
if u got the money u should pick up an external hard drive. that way u can transfer your music and back up anything else on your computer.
6,682
49
Don't forget to copy over your profile info as well.
And if your new PC is running Vista... you might have a few problems with iTunes.
OJsakila
Jul 15, 2007
3,021
Jupiter's sulphur mines
My telepathy isn't working right now... You're going to have to explain your problem a little better. Its hard to read an eighth grader's mind...
You trying to transfer to a computer or from a phone or what?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Use a thumb drive, copy the iTunes folder from hers to yours, then on your computer, load iTunes and then under edit/preferences/general...right there you can change the folder to look at the folder of iTunes you just brought in.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Either that or import all the songs from the thumb drive to your iTunes folder on the new computer and the consolidate them so they'll all be in the iTunes folder and not on the thumb drive anymore.
ColsTiger
Mar 8, 2007
5,856
Columbus, GA
Let's play nice now. It's a common problem.:)
