Vibrating keypad
redneck47441
Jun 3, 2009
120
I was wandering if when texting if there's an option to make the keypad vibrate when you press a key on thetouch pad
iphonewarrior
13,847
702
Yes you can,
i knew there was once an app available (only through Jailbreaking your device) called Vibrus.. There may be more out today.
redneck47441
Jun 3, 2009
120
I don't want to have to jailbreak my phone I read something about downloading mobile enhancer but I think that only works on the 1st gen iPhone right? Anybody else know of a way to get a vibrating keypad for my 3G?
iphonewarrior
13,847
702
Have you done a search in the app store?
There is only one I came across and it's an email vibrating keyboard. That's it. I am on the UK iTunes store so it might differ from yours.
redneck47441
Jun 3, 2009
120
I have the same app but i'd like it for texting
iPhoneMonster
Jan 18, 2009
461
I'm just wondering, would this damage my phone in any way?
iphonewarrior
13,847
702
I'm pretty sure it wouldn't- because its in the app store, its obviously been tested and approved by Apple.
So i think you'll be fine.
iPhoneMonster
Jan 18, 2009
461
Yeah, but i'm not relying on Apple and their 'testing' and 'approval'.
iPhoneMonster
Jan 18, 2009
461
It's just their approvlal is really bad so maybe they aren't testing the app at all? Or much anyway. Also if my iPhone malfunctions because of an app store app is that covered?
iphonewarrior
13,847
702
I understand your questioning, but... Apple stop stupid/bad/apps that Apple don't approve of- they usually turn up on cydia anyway.
It's frustrating i know, especially to see apps rejected which could cater to your everyday needs. I wouldn't not trust Apple's approval- it's a bit of a silly comment to make. This thread it about a vibrating keyboard and you guys are getting a little deep into it. The phone vibrates.. and Apple have obviously noted that this is going to use the built in vibrate more and it will deplete the battery more (stating the obvious). I see no disclaimer saying the use of this app voids your warranty.
So it's pretty much 'case closed' in my eyes.
15,385
1,089
Not so ridiculous. Consumers should think about what apps may do to their devices.
In this paricular case, I think your battery would get used much more quickly if you do a lot of textng/email with the vibrate on.
