Vibration no more?
TeamPEZ
Sep 7, 2008
47
Marietta, Georgia
I just got a replacement iPhone yesterday as it was crapping out (shutting down/low power, etc) and they happily traded it out for a new one.
My only problem is that I can't feel the vibration when I get a text. Usually I can feel it, if not hear the vibration, but it won't work now. Is there anyway to make the vibration last longer or even louder?
Thanks!
-Corey
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
Have you checked to see if it's turned on in settings?
You might want to try restarting the phone to see if they might work.
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
Then it could be possible it's an internal problem with the motor or flex cable. You might need to take it back.
