Vibration pattern
Dipsxxy
Aug 1, 2010
174
74
From what I've heard, you can create a custom vibration patter on the iPhone 5? Where in iOS to do I go and how to I setup my vibration pattern?
Kriss
Jun 8, 2008
598
121
43
Cape Cod
voyager01.deviantart.com
Found this on Google.
Settings app, and selecting General and then Accessibility), and enable Custom Vibrations.
2. Navigate to Settings, Sounds, Vibration to record a custom vibration pattern that will replace the default iPhone vibration.
3. Use the touchscreen to tap out a custom vibration pattern. When you're finished, tapStop. To double-check your pattern, press the Play button; then save the pattern with a custom name.
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
I think it moved in iOS 6. Go to settings-sound and choose whatever you want a custom vibration for. Go to the top and touch the "vibration" button where you can set up your custom vibration.
