Video compression
xsbx
Jan 5, 2008
40
Ok so I want to put some movies on my iPhone but they turn out to be like 700 to 1 gig. Is there some special compression method to reduce the size?
x999x
Aug 6, 2007
1,656
The problem with further compression is that the video quality goes down considerably.
700m to 1g is average for a decent quality movie.
The iPhone has a very high resolution display and working on anything less than a 1:1 scale ratio is unfortunately going to become evident because the screen will show you all the video's flaws.
ChArLiE713
Jul 3, 2007
149
Everytime i try to sync a movie that i converted with Videora, it doesn't show up under videos. I mean, it syncs into the phone but it goes under "Other" on the memory thing you look at the in iTunes. It takes up memory but it is not there. Can anyone help me?
psylichon
Oct 31, 2007
16,591
751
40
Philly
I use Videora at the lowest video bitrate settings (still looks more than fine on the small screen) and it will reduce a 90-minute movie to around 250MB.
Regarding the issue with the videos showing up strange on the iPhone, I dunno... it's always just worked for me. Check the settings as to where the video is saved perhaps?
Or just uncheck the option to automatically import into iTunes and do it manually...
amiroo79
Nov 3, 2007
217
Southern California
have you at any point used the SwapTunes app?
amiroo79
Nov 3, 2007
217
Southern California
swap tunes does not apply. He is trying to get iTunes to see the movie he converted, that is the problem.
it might. i had the same issue when i used swaptunes with videos showing up in the "other" portion of memory. either way, it's fixable. what he has to do is manually put it in there by going to the media folder and go to the iTunes_Control folder where he can move the videos and put them in the right place. and if he does have swaptunes, he needs to delete the second iTunes_Control folder.
it's all fixable...
Eragon
Jan 8, 2008
3,056
49
Frederick, MD
Where in iTunes does your video show up after you've imported? For it to sync with your device, it must be in a compatible format (mp4, m4v, mov, etc.). Right click or ctrl-click the video title, and look up get info.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
When you import a movie into iTunes, you actually don't put it in iTunes. It stays where ever you made it, it only points iTunes to your file. If you move that file, iTunes does not know where you moved it to until you show it where it moved to.
Eragon
Jan 8, 2008
3,056
49
Frederick, MD
Thanks for the clarification, KNK. I've forgotten that I configured my iTunes library to consolidate audio and video files in the same music folder. :)
Back to the OPs issue, video files will have a specific tag (e.g., mp4, m4v, mov). The OP should check the file being incorrectly synced to see if it is compatible with the device. A WMV file won't play in iTunes, but could it sync over to the device as an "other", especially if the device is set to disk mode?
